adityalagudu
- Oct 2, 2020
- 18
One of our essential old motor is running on 4160V, but the Electromechanical relay is set at 4000V. The current overvoltage trip for the motor is at 1.1 X rated (i.e 4400V) and the alarm is 1.09 X rated (i.e 4360V). Recently the motor tripped due to Overvoltage. We are looking for options to keep this motor running safely. As this is an essential motor we want keep the Alarm settings and disable the trip setting. Or we would like to change the voltage set value to 4160V instead of 4000V, as it doesn't make any sense to keep the voltage as 4000V when the motor is running at 4160V. Would appreciate it if you could provide your comments
