Wandering Wallaby
- May 4, 2020
- 19
Hi everyone, first time posting to this site but have used it for years for guidance, so thank you! Anyways, I am in the process of gathering my MWFRS diaphragm loads and am looking for advice on how to model the parapet loads when there are multiple parapets along the length of the roof. The project is a large 8500 square foot flat roof residence with 11 separate roof diaphragms with multiple vertical offsets separated by parapets. In one area there are 8 different parapets that the wind would flow over. Per ASCE 7-16 C29.5 “There should be no reduction in the positive wall pressure to the leeward parapet caused by shielding by the windward parapet because, typically, they are too far apart to experience this effect.” My question is, how far is “too far apart?” A lot of these parapets are around 16 ft apart and about 3-4 ft tall. Obviously, the load increases significantly if treated as 8 individual parapets with no shielding effect, so I’m just trying to see what other engineers have done in this situation.
Thanks in advance for any help.
