Imposter666
I have an SMC cylinder with 50mm Dia operating at 60psi. I need to design a pneumatic circuit that would enable the cylinder to push with 10-25% its capacity (I need a pressure regulator to adjust as needed) at the start. Then once the part is lifted of the table, I need the cylinder to push down with 100% of its capacity. I will have a part present sensor to communicate to the SMC manifold/valve that it is time to apply the full pressure. What kind of 5/3 valve and pneumatic circuit would I need for this?
