bryansonnier
- Dec 20, 2011
- 80
NACE MR0175 calls out specific hardness testing requirements for certain materials. In order to test for hardness, you can't just thump the piece of steel and listen, like testing a watermelon (although technically speaking there are tools that do just that). Is there an approved standard or standards for testing hardness? If so, what are the pros and cons of them?
Basically we have to test small runs of parts probably 50 a year or less. A large benchtop rockwell tester seems too expensive but can i rely on the much cheaper Leeb testers to in the very unlikely event there is a failure we could say "we tested the hardness" and not get laughed out of court. We are trying to determine which one to purchase. If the benchtop is the only way to go, i don't think our product would be competitive and we may as well not be in the market, but I want to create a safe product as well so i'm hoping for a little guidance.
EDIT:
So i've looked at some of the ASTM standards and there is a standard for portable rockwell testers (ASTM E110) and also for leeb testers (ASTM A965). The leeb testers are much more economical but is there any thing anywhere that states you should use this and not that when it comes to NACE (specifically MR0175) or is it just up to the discretion of the customer requirements. If just the customer then there may be an issue because as far as most of our customers are concerned if you hit it with a hammer and it goes ping and not bong its hard enough. I'm being sarcastic here but not by much.
EDIT:
