Nadadenko Antenna 1
RamonMayorMartins
1
Anyone have the layout of Nadadenko antenna ?
Ramon Mayor Martins
Telecommunication Engineering
I've never even heard of it, in spite of paying attention to antennas for decades. And, interestingly, neither has Google.
Can you provide any context? Application? Is it a designer's name, or a brand name?
Well found!!
They're typically called a 'cage dipole'.
The effectively thicker elements basically lowers the Q and widens the bandwidth.
Use this antenna as broadband but in that case you should use an open line feed line 200 -300 OHm. Using this feed line the losses even with SWR=10-15 will be not to high vs the regular coax line feeder.
Alex,
alexantdesign.com
