name field in properties 1
Lars1978
327
Hi All,
Please see beneeth the assembly navigator with a file maked (greenish) and the properties of this file shown in the right. Iv got this file originaly as a .stp file. I see the name on the left (new name) differs from the name on the right. :(
Where can I find the attrute which shows the name out of the properties field.
I'd like to have this name always be the same in the assembly navigator and the name field at the properties.
Oh it seems in mij drawing the name out of the properties is used instead of the discriptive name in the assembly manager...
Any suggestions....
Lars
NX native (NX13 or NX1847)
Solid Edge ST10
Inventor
Solidworks
The name in the properties field is the name (taken from the part) that the Component gets when it is First added to the assembly. It is also "in context of the assembly". You can change it in the properties without changing it for the part itself.
This will not automatically change anymore...Even when you substitute the component it will still stay the same.
So making it ALWAYS the same in the navigator will be hard to accomplish.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
Ronald,
you can delete the component name( the x in the right menu above)then then it gets "reset".
I think i wrote an Enhancement request on that sometime during the 90-ies....
Tomas
I guess they couldn't get around to that just yet.....but we have new icons (again)! [2thumbsup]
Tim Flater
NX Designer
NX 11.0.2.7 MP11 Rev. A
GM GPDL 11-A.3.5
Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
No, what i am saying is that it was impossible to get rid of component names , long time ago, and hopefully I helped remove that issue. :)
I still haven't seen the new icons, - i assume that it is the 1847 icons you think of.
I personally do not like the "flatter, whiter, appearance and less 3D" of later MS/ Windows ( Win 8 and later) Not to mention the "innovative user interfaces" that some apps have started with.
i guess that the new icons are "flatter", less colorful, and less intuitive...
Tomas
Apologies for straying off-topic.
Thanks for taking the wind out of my sails, Tomas. J/K
As far as the new icons - for me, it's not really a matter of how they look. I just feel there's more important things to work on than the "theme" of the icons at this point in time. Too many current users and users coming from other softwares pointing out shortcomings for me to be convinced that icons should be a high priority to anyone right now. I'm not completely irate about it, just disappointed. To be perfectly honest, not surprised at all that this happened - par for the course.
You judge for yourself what you'd call the new icons. I haven't had the misfortune of using Win10 yet but it's coming soon from what I've been told. Someone definitely likes cyan and orange and grayscale (what I call the late 80s Apple Mac icons).
Tim Flater
NX Designer
GM GPDL 11-A.3.5
Toost said:
Ronald,
That is what I said....needs manual interaction
NX9 / TC10.1.2
If memory serves, someone posted a journal on the Siemens site a while back that would set the component name to be the same as the part file name. A quick search didn't yield the exact journal that I was thinking of, but here are a couple similar ones:
If you always want the component name to match that of the file name, a journal could be made to set the component name and this could be set to run on part open (or part save, or some other user exit).
www.nxjournaling.com
I misunderstood you there Ronald.
Tim, i do agree on this. I can name quite a few things i rather would spend development money on than new icons.
- I still haven't seen the light in the ribbon bar...
/ Tomas
So the only way to change the component name into the part namer aka file name is to write a journal?
Oh I'm with you all regarding the icons.... I rather like other developments... (my best hope i that the icons are not made by the development team (programmers) at siemens :) )
Lars
Solid Edge ST10
Inventor
Solidworks
No, you could delete the name (as mentioned above) or rename them manually. The journal would only be useful if you have a lot to rename at the same time.
can I have a colum in the assembly navigator which shows this name?
I can't find it...
Lars
Solid Edge ST10
Inventor
Solidworks
Ok thnx
Lars
Solid Edge ST10
Inventor
Solidworks
Try this, it should help.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Module NXJournal
    Public theSession As Session = Session.GetSession()
    Public ufs As UFSession = UFSession.GetUFSession()
    Public lw As ListingWindow = theSession.ListingWindow
    Sub Main()
    Dim workPart As Part = theSession.Parts.Work
    Dim dispPart As Part = theSession.Parts.Display
    lw.Open
    Try
        Dim c As ComponentAssembly = dispPart.ComponentAssembly
	if not IsNothing(c.RootComponent) then
            ReportComponentChildren(c.RootComponent, 0)
			ReportComponentChildren2(c.RootComponent, 0)
        else
            lw.WriteLine("Part has no components.")
        end if
    Catch e As Exception
        theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
    End Try
		lw.Close
    End Sub
' Empty run
Sub reportComponentChildren( ByVal comp As Component, ByVal indent As Integer)
    For Each child As Component In comp.GetChildren()
	Dim MyPart As Part = child.Prototype.OwningPart
	Try
		if child.IsSuppressed = true then
			lw.writeline("   Error: " & child.DisplayName & ".prt" & " -> " & "File closed")
			Continue for
		end if
			Catch e1 As Exception
		        theSession.ListingWindow.WriteLine("Failed: " & e1.ToString)
	end try
        If LoadComponent(child) Then
            Else
                'component could not be loaded
            End If
            reportComponentChildren(child, indent+1)
        Next
    End Sub
' Changing file name
Sub reportComponentChildren2( ByVal comp As Component, ByVal indent As Integer)
	Try
			lw.writeline("Error: " & child.DisplayName & ".prt" & "   " & "File closed")
			exit sub
		end if
		end try
            Dim TextLength as Integer
            Dim File_name as String
	    File_name = child.DisplayName()
	    TextLength = File_name.Length
 		'lw.writeline(File_name)
		lw.writeline("component name: " & child.Name & "-> " & File_name )
		child.SetName(File_name)
		lw.writeline("new component name: " & child.Name)
		'lw.writeline("ref set name: " & child.referenceset)
		'lw.writeline("component part name: " & child.Prototype.OwningPart.fullpath)
		lw.writeline("")
	Else
	End If
            reportComponentChildren2(child, indent + 1)
        Next
    End Sub
' Function loading components
 Private Function LoadComponent(ByVal theComponent As Component) As Boolean
        Dim thePart As Part = theComponent.Prototype.OwningPart
        Dim partName As String = ""
        Dim refsetName As String = ""
        Dim instanceName As String = ""
        Dim origin(2) As Double
        Dim csysMatrix(8) As Double
        Dim transform(3, 3) As Double
        Try
            If thePart.IsFullyLoaded Then
                'component is fully loaded
            Else
                'component is partially loaded
            End If
            Return True
			Catch ex As NullReferenceException
            'component is not loaded
            Try
                ufs.Assem.AskComponentData(theComponent.Tag, partName, refsetName, instanceName, origin, csysMatrix, transform)
                Dim theLoadStatus As PartLoadStatus
                theSession.Parts.Open(partName, theLoadStatus)
                If theLoadStatus.NumberUnloadedParts > 0 Then
                    Dim allReadOnly As Boolean = True
                    For i As Integer = 0 To theLoadStatus.NumberUnloadedParts - 1
                        If theLoadStatus.GetStatus(i) = 641058 Then
                            'read-only warning, file loaded ok
                        Else
                            '641044: file not found
                            lw.WriteLine("File not found")
                            allReadOnly = False
                        End If
                    Next
                    If allReadOnly Then
                        Return True
                    Else
                        'warnings other than read-only...
                        Return False
                    End If
                Else
                    Return True
                End If
				Catch ex2 As NXException
				if ex2.message = "File not found" then
	                lw.WriteLine("Error: " & partname & "   " & "File not found")
				else
	                lw.WriteLine("Error: " & partname & "   " & ex2.Message)
				end if
                Return False
            End Try
        Catch ex As NXException
            'unexpected error
            lw.WriteLine("error: " & ex.Message)
            Return False
        End Try
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        Return Session.LibraryUnloadOption.Immediately
    End Function
End Module
With best regards
Michael
