NAS 4002 Fastener Area Calculation. Aerospace UNJ Thread
gfthelen
Materials
Nov 9, 2011
9
Hello All;
Not sure this is the place for this question, but....
For this NAS 4002 Spec, Fastener Testing, Table III shows the Nominal Thread size and TPI, the Nominal Size (IN.) and the Thread pitch area at Max Dia.
Then the values for Min Tensile for Types I, II and III.
Is there a formula for this UNJ stress area of the fastener?
The standard F-606 Area Calculation is NOT correct for this sample. This formula uses the Thread Pitch Dia. in the equation. Would like the formula so I can direct calculate the area in place of a look up table to find area.
Thanks for your help and I have attached the Page for this table.
Greg Thelen
 https://files.engineering.com/getfile.aspx?folder=be351bb1-3617-485d-a51d-9306959aa92e&file=NAS4002_UNJ_areas.pdf
gfthelen,
I have the Handbooks of Bolts and Bolted Joints here, by John H. Bickford and Sayed Nasser. Bickford's stuff has been highly recommended over and over again. On page[ ]165, they show the following...
AT = [π]/4 [×] (D - 0.9743/n)2 [—] inch series
AT = [π]/4 [×] (d - 0.9382p)2 [—] metric series
AT = [π]/4 [×] (D - 0.6495/n)2 [—] inch UNJ series
AT = [π]/4 [×] (d - 0.6495p)2 [—] metric MJ series
[ul]
[li]D is the nominal size in inches.[/li][li]d is the nominal size in mm. [/li][li]p is thread pitch in millimetres. [/li][li] n is the number of threads per inch.[/li]
[/ul]
JHG
JHG:
Just making sure of this: Your Metric MJ Formula is showing "n/4" do you mean "p/4" Since it is Metric
gfthelen,
My formula is showing pi over four.
"n" "[π]"
Fun with font rendering?
JHG
Thank you
My eyes are getting too old for me.
GT
