NASTRAN: Restart from sol 106 into sol 103
NicolaPalettaPhD
New member
Mar 14, 2012
3
Could someone explain me how can I do a restart from sol 106 into sol 103? The purpose is to calculate normal modes by using differential stiffness matrix from sol 106 but by changing buoundary conditions.
In other words, I have to calculate free-free normal modes with sol 103 by using the differential stiffness matrix from sol 106. This last procedure has been used to calculate a non linear static solution with a self-balanced load condition (aerodynamic + inertial + propulsive loads) by restraining the FE model grid representative of the whole airplane center of gravity.
Thanks for you help!
Hello!,
With FEMAP & NX NASTRAN SOL 106 you have an easy way to perform modal analysis with pre-load. The key is to put the METHOD command in the case control and put an eigenvalue card, such as EIRGL, in the bulk data session. Also, param LGDISP needs to be specified to compute the differential stiffness, and NMLOOP should be a value not equal to zero so that the normal modes are computed based on the updated non-linear stiffness.
Here is an example:
$ Normal Mode Analysis with Preload - Solution 106
$ Note that LGDISP = 1 is set to get differential stiffness matrix
$ case control METHOD = 10 calls eigenvalue module
SOL 106
CEND
TITLE = Normal Modes with Preload
SUBCASE 1
NLPARM = 1
LOAD = 1
METHOD = 10
SPC = 100
DISPLACEMENT = ALL
BEGIN BULK
$------8-------8-------8-------8-------8-------8-------8-------8-------8-------
8
$ Param Cards
PARAM WTMASS 0.00259
PARAM COUPMASS 1
PARAM POST -2
$ Nodes
GRID 1 0 0. 0. 0.
GRID 2 0 10. 0. 0.
GRID 3 0 20. 0. 0.
GRID 4 0 30. 0. 0.
GRID 5 0 40. 0. 0.
GRID 6 0 50. 0. 0.
GRID 7 0 60. 0. 0.
GRID 8 0 70. 0. 0.
GRID 9 0 80. 0. 0.
GRID 10 0 90. 0. 0.
GRID 11 0 100. 0. 0.
$ Bar Elements
CBAR 1 11 1 2 0. 1. 0.
CBAR 2 11 2 3 0. 1. 0.
CBAR 3 11 3 4 0. 1. 0.
CBAR 4 11 4 5 0. 1. 0.
CBAR 5 11 5 6 0. 1. 0.
CBAR 6 11 6 7 0. 1. 0.
CBAR 7 11 7 8 0. 1. 0.
CBAR 8 11 8 9 0. 1. 0.
CBAR 9 11 9 10 0. 1. 0.
CBAR 10 11 10 11 0. 1. 0.
$ Bar Properties
PBARL 11 12 I +
+ 2. 1. 1. .1 .1 .1
$ Material Properties
MAT1 12 1.0E+7 .33 .101
$ Restraints
SPC1 100 345 1 THRU 11
SPC1 100 1234 1
SPC1 100 234 11
8
$ EIGRL Card for Eigenvalue Specification
EIGRL 10 3
$ PARAM Cards: LGDISP & NMLOOP
PARAM LGDISP 1
PARAM NMLOOP 5
$ NLPARM Card
NLPARM 1 5 AUTO 5 25 PW NO+
+ 0.001 1.0E-7
$ FORCE Card
FORCE 1 11 0 500. 1. 0. 0.
ENDDATA
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: Blog de FEMAP & NX Nastran:
Thank you for the answer Blas.
I did as you suggest in the first time, but the problem is that this approach does not let me change the boundary conditions. More in details, I have to remove the constraint used for running the sol 106. I need to calculate normal modes for an unrestrained condition.
thank you again.
Best regards
Nicola
