National Pipe Thread 2
TheMotionGuy
38
0
0
I am not completely familiar with NPT. How do you read an NPT callout. I know we don't need to call out depth, as that is per machining spec.
The callout is a 1/8-27 NPT. Is the 27 just referring to threads per inch? And since an NPT hole is tapered, is 1/8 the diameter of the inside part of the hole or the outside?
I just want to make sure of what I am getting made so I can purchase the proper fittings.
A part that was touched on in the Wikipedia article, but was not mentioned is that the NPTF (National Pipe Thread Fuel) when used, can only be counted on for a leakproof connection one single time. If the two parts are ever disassembled or backed off, they have to have sealing dope or tape applied to the threads to guarantee a liquid-tight seal.
Engineering is not the science behind building. It is the science behind not building.
Thank you, Tex. During my research, I did read that somewhere as well (don't remember where). The parts shouldn't have to be disassembled--but in the even that they are, I will keep this in mind.
To answer your questions:
1) You just call out 1/8 NPT. I like to put on 1/8 MNPT, "M" for male or Pin, 1/8 FNPT, "F" for female or Box, but I find the machine shops prefer not to use such identification on the prints.
2)the "1/8" is a nominal size reference and has no physical meaning. The OD for this NPT geometry for example is 0.405 inches on the male.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
I've seen the MNPT/FNPT designation before, too. It occurs to me, though, that one should be able to tell whether a thread is internal or external just bt looking at it.
I had a spec called out "FNPT", and I mad a point to clarify that it did NOT mean "NPTF". I think it is generally unnecessary to state male or female, except perhaps in a wholly written description of the parts involved where no other context would be available.
Mike
Metalonis has it right though, SnTMan, a casual glance at the print pretty much defines Box from Pin. "F" and "M" are redundant as far as labelling goes.
Principal
