We are working on a project in which the medium-pressure gas piping was sized for 2 psig, but the available pressure is 1 psig. We are currently sizing the pipe for 1 psig, which will require tearing out and replacing a significant amount of pipe.
Do you know if it is legal and feasible to install a small booster compressor to boost the pressure from 1 psig to 2 psig? If yes can you suggest a make/model?
The meter has 10 psig at its inlet, but the utility will only allow 1 psig at the outlet.
The total demand is around 5,000 cfh.
Thank you
Thank you
