Natural Gas Processing Of Offshore Gas ..... 2
processendbd
Chemical
Jan 10, 2014
58
Though I found some material but still have some questions regarding offshore natural gas?
What are the largest pollutants in offshore natural gas?
Are the gases can be processed in offshore platform or have to be brought to the shore for processing?
Does transportation of Natural Gas causes problem in the pipelines?(Corrosion/ blockage )?
Is it relatively cheap (capital/operating) to process them onshore?
Sorry for typo if any.
Would really appreciate your response.
frankly speaking the material you found is very poor, otherwise you would have already had the answers.
you can just start with wikipedia....
in principle, there is no difference between offshore and onshore gas.
anyway:
- pollutants: water, CO2, H2S, N2, mercaptans, He, Hg, heavy hydrocarbons
- the gas can be processed either offshore or onshore
- transportation causes troubles if not well designed
- non sense question. it depends, mainly, by the site position and conditions
good luck!
