NCEES Record
HornTootinEE
134
There may be another thread on this, but does anyone know the typical Review period for an NCEES Record? Mine has been on "Review" status for approaching two weeks now...
Once they received all my references, state PE/FE info, and transcripts, it was about 30 days.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Varies from state to state. I've had everywhere from 2 days to 9 months.
I think the NCEES process is more dependent on how many states you are licensed in. I was in 1 state and it was around 30 days. Their web site used to say that each additional state added 2 weeks, but I couldn't find anything on it just now.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
I sent them the application, transcripts, foreign degree evaluation, professional references, experience records and PE/FE information all within about month's time. After about 3 weeks my records was established and then they sent me a certificate stating my records and my records number. Upon yearly renewal of the records, I also got a small wallet size records certificate reminding me of my next renewal date. I hope this helps you. Establishing the records has worked great for me in getting licensed in other states as well. Good luck.
Took me about 4 weeks and I felt like it would have been much longer if I hadn't called and inquired. Once I called, it was approved within a day. Weird coincidence maybe but probably not.
PE, SE
Eastern United States
"If a builder builds a house for someone, and does not construct it properly, and the house which he built falls in and kills its owner, then that builder shall be put to death!"
~Code of Hammurabi
Thanks for the input. Helps to know how long it will take. I am only licensed in one state currently, but will need to add about 6 more-hence the reason for the record.
Dan J
NCEES record is a good thing to have. Georgia, for example, requires it now.
Best to you,
Goober Dave
August is a slow month; a lot of people take vacation. I updated my record one month ago and still haven't my new card.
