Hi all,
In one of our projects, we requested to VENDOR for a Fire test Certificate for the Metal seated check valves. But the VENDOR replied that, metal seated valves are intrinisically fire safe and no fire test is applicable.
But when i had gone through the API 6FA / ISO 10497, they mention 2 types of leakages, which are internal leakage caused by seat failure and the other is external leakages which are visually detected other than the welding joint leak in the valve to pipe connection.
And in both standards, they no where specify the non requirement of fire test for metal seated valves.
Please clarify in the above and also, if it is intrnisically fire safe, how it shall be determined.
ET
ET
