"Hey, can you send me the Association of American Railroads?"
And submit the specs on the Space Shuttle too. I'll need those.
Building a motor from scratch is certainly possible.
Here is a brief list of raw materials you'll want to seek out.
Silicon Steel Sheet. (Or a box of common nails.)
Electrical Insulation Material (Various kinds too numerous to list.)
Insulated Magnet Wire. (Numerous AWG sizes down to about a number 36.)
The above materials provide for the electrical aspect of your machine.
But! You'll also need the mechanical portions of your machine which consist of the rotating
elements. These items will have to be constructed from scratch as well.
You didn't specify if you want it powered with Direct Current, or Alternating Current.
An A.C. motor at the speed you're seeking would be physically larger in diameter
than a D.C. apparatus.
How would you make one?
For starters, you would consume everything you could possibly learn on the subject matter.
This exercise by itself will take a considerable length of time and study.
Once you've discovered you're not able to absorb all the facts and relationships
making up the [workings] of a motor, you'll look for compromises.
For your first step, I'd say you have started in the right place declaring your required operating voltage.
Soliciting or farming the Internet to help you with your objective (in a subtle way)
indicates your objective is possibly a passing pipe dream.
If you're up to the challenge though, get started on your motor.... get it to
turn, and come on back to this forum with some data, photos, and results of your attempt.
Then, maybe then...
John
