County is installing new water lines and I have the option of 1" or 2" connection. I'm concerned about pressure loss due to distance and elevation change. The water line will be sch 40 PVC approximately 300lf, with approximately 5' elevation rise, and two each 90degree fittings. Inlet pressure will be 60-65psig. My maximum flow rate will be no more than 10 GPM. I'm concerned 1" will not be sufficient . They want 4 times as much to go from 1" to 2", both being my only options. Any advise would be appreciated.
Thanks, Ray
Thanks, Ray
