Need help creating Delta Angle Symbol in dimension text 1
MrCivilDrafter
4
I need help creating Delta Angle Symbol in dimension text. You know that little triangle symbol. Is there a key command to make it like the degree symbol (Alt+248)?
thanks
What version of autocad are you running?
If you have autocad 2006 it is built into the multiline text editor.
I finally figured it out.. I went to Help in Autocad (2006 by the way) did a search on on Delta, and found a topic called "Symbols and Special Characters"
the command is \U+0394
thanks though
