blades741
- Aug 1, 2012
- 47
Hello all, and thank you in advance for the help I know I'll receive here. You've collectively been so helpful in the past, and I thank you for that!
I work for a company who's core manufacturing process is laser cutting & bending sheet metal parts. For the sake of this question, we can disregard the sheet metal bending aspect. Most of our parts start out as a flat pattern of a bent part. These flat patterns can be complex in shape, and also contain complex shapes cut out of them. Fully dimensioning them is neither practical nor necessary, as we deal with the DXF files for use in laser or water-jet processing. I know I can add a SURFACE PROFILE note or title-block tolerance that can control the outer profile of the part, but can this same profile tolerance control the interior profile shapes (slots, holes, complex contours, etc.)as well as the location of these various cutouts within the part? Would a "CAD IS MASTER" note along with the general surface profile tolerance note be sufficient to convey the intent of both the profiles and location of the profiles?
