Need help for save as journal
patrice vallet
Industrial
FR
Currently, I work with an assembly composed of family part member
I have not problem when I work on standard products, but for special products, I need to clone the assembly and family part members to do specific modification.
I can’t use cloning function to rename my assembly and parts and save it on a other directory, due to the use of family part.
Currently, I do several “save as” to do it, but it’s time consumer.
I would to do a NX journal to do it. The journal will have to :
Ask the user to choose a save directory
Ask the user a number (exemple : 145145)
Save the active assembly and the part under it in the save directory
Rename all part with the number as suffix (exemple : part_145145.prt)
I work on NX10
Could you help me to create this journal ?
Thank you
Patrice
I success to ask a directory, and a number to the user. And save the work part.
But, now I don't know how do this action on all the parts under the work assembly.
Could you help me, please ?
Code:
Option Strict off
Imports System
Imports NXOpen
Imports System.Windows.Forms
Imports NXOpen.UF
Imports NXOpen.Assemblies
Module Main
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim workPart As Part = theSession.Parts.Work
    Dim lw As ListingWindow = theSession.ListingWindow
    Public Folder as String = nothing
    Public dispPart As Part = theSession.Parts.Display
    Sub Main()
        'demande chemin sauvegarde
        lw.Open()
        Dim FolderBrowserDialog As FolderBrowserDialog = New FolderBrowserDialog()
        FolderBrowserDialog.SelectedPath = "C:"
        FolderBrowserDialog.Description = "Selectionner le dossier ou doivent être sauvegardé les pièce"
        If (FolderBrowserDialog.ShowDialog() <> DialogResult.OK) Then Return ' Sort si le user n'a rien indiqué
        Folder = FolderBrowserDialog.SelectedPath
        lw.WriteLine("Le directory choisi est :" & Folder)
        'demande numero projet
        Dim numeroProjet As String = ""
        numeroProjet = InputBox("Enter project number", "numero projet", "")
        '   Save As...
        Dim partSaveStatus1 As PartSaveStatus
        Try
            partSaveStatus1 = workPart.SaveAs(Folder+"\"+workPart.Leaf+"_"+numeroProjet+".prt")
            partSaveStatus1.Dispose()
            Catch ex as Exception
        End Try
    End Sub
End Module
