Thanks again for the help. I followed the instructions by
itsmoked and the laptop is now working great. I'm new to soldering and it's not the best looking job, but it does work. See the pictures at
and
. I'm curious, how should one hold this part still while soldering it? I guess you would use an alligator clip. I didn't have one, so I put a drop of Super Glue on the bottom of the inductor and that held it while I soldered it. I realize this would have caused a problem if the part had to be removed, so next time I'll use a different method. Any suggetions?
As I mentioned in my original post, I was repairing a broken notebook computer jack when I broke the inductor off. This is the first time I have done such a repair. The jack had broken loose from the circuit board. I wasn't sure if I should solder the top or the bottom of the jack, so I soldered both. See pictures at
and
. So I'll know next time, please let me know what should be soldered, top, bottom, or both? I didn't see any traces on the bottom, but I thought maybe they are in a layer below, or at least the solder would help hold the jack in place.
As mentioned in my original post, the jack repair did not work when I first attempted the repair. I'm wondering, would the broken inductor have caused this? It works fine now, but I resoldered the jack in addition to soldering the inductor back on.
Thanks again for helping out a newby. I hope to learn enough so I can become proficient at repairing broken notebook jacks.
