Need Help Lofting/Sweeping a Complex Profile
MDGroup
230
I can visualize it in my head, but can't figure out how to get make it in the model.
I have a coiled rectangular profile.
In the center, I need it to twist and curve so it exits pointing downward with a square profile.
I need it to have a nice smooth transition maintaining the same minimum cross section area in the center.
My first thought is a loft, but it really messes up the profile, and deforms into a really akward shape. (Maybe just need to add some guide curves on each corner, but can't figure out how to create the nice smooth sweep I need.
Attached is an image of the loft, which is the basic idea I am looking for, but needs to be a lot smoother.
Also the SW file if any one wants to take a shot at it.
Thanks in advance.
-Lou
 https://files.engineering.com/getfile.aspx?folder=6c727121-5eb1-4598-82e7-bfc922012366&file=Coil_-_Bad_Loft.PNG
1. my first thought is to get the outside modeled, and then use a shell command to hollow out the inside and maintain a constant wall thickness.
2. my second thought is how will you fabricate this part?
