MrEureka,
Is this the coin in question?
"Diameter: ±19 millimeters
Metal content: Copper ±88%, Nickel ±12%
Weight: ±72 grains (±4.7 grams)
Edge: Plain
1857 saw the end of an era as the old, bulky Large Cents were replaced with a new, smaller One Cent .... The metal composition was changed from nearly pure Copper to a Copper-Nickel mixture that gave added strength and a lighter color, earning the coins the nickname "White Cents." To ensure widespread distribution, the Mint produced over 17,000,000 of the new Small Cents, nearly six times the production of Large Cents in the previous year."
--- Collectors Universe, Inc.
Similarly, from the US Mint website, for the cent coin:
"The composition was pure copper from 1793 to 1837.
From 1837 to 1857, the cent was made of bronze (95 percent copper, and five percent tin and zinc).
From 1857, the cent was 88 percent copper and 12 percent nickel, giving the coin a whitish appearance.
The cent was again bronze (95 percent copper, and five percent tin and zinc) from 1864 to 1962."
Regarding EDS, WDS & XRF analytical methods.
Electron microprobe analysis (EMPA), uses wavelength-dispersive spectroscopy (WDS) so has diffracting crystals to separate the x-rays excited from the sample. With high purity standards and a flat, polished sample surface, accurate to 0.01 wt%.
SEM with EDS (energy-dispersive spectrometry, EDAX is an analyzer brand name), is accurate to about 0.1 wt% for standardless analysis, maybe 0.025% with standards. Has pretty much displaced WDS since cheap to attach to an SEM and simpler construction, with a single multichannel analyzer allowing line and area scans (rastering) w/o affecting relative sample-to-detector geometry.
XRF has interference problems when analyzing metals of similar atomic weights. Although an X-ray beam may pass deeper into a specimen than an electron beam as used in EDS or WDS, the fluorescing x-rays detected are from a much shallower volume, 0.1 micron vs. characteristic x-rays from a 1 micron deep volume in EDS or WDS. Makes it useful for plating thickness & composition measurements. Takes good standards and very good software to be accurate.
Regarding the 1857 alloy. I agree that the iron content likely is an impurity, mostly in the Ni. But, the Zn seems too high to be accidental. I tried to find refined copper & nickel analyses ca. 1857 but so far unsuccessful. Analyzing other coins of similar vintage as suggested above is a good idea.
At that time, most of the copper matte (semi-purified sulfide) produced in the US & elsewhere was shipped to Swansea, Wales, for treatment -- roasting to blister copper and then fire refining (oxidizing off less noble metals and sulfur) + poling (inserting wood poles to deoxidize) to produce tough pitch copper. Note: the electrolytic refining of copper on a commercial scale began in 1869 at Pembrey in Wales. --
A Hundred Years of Metallurgy, pp. 128-132 & 140-141 (1963).
In
Handbook of the Non-Ferrous Metallurgy, vol. 2, p. 248, (1945) Lidell gives analyses of blister copper from 5 smelters -- 98.4-99.5% copper, av. 0.12% Fe, av. 0.10% Ni, av. 0.035% Zn; also As, S, Sb, Pb, Ag & Au in lesser amounts. Subsequent fire refining + poling improves the purity. The current specification ASTM B216, 'Standard Specification for Tough-Pitch Fire-Refined Copper,' gives compositions Cu 99.88% (min), Ni 0.05% (max), Se + Te 0.025% (max), As 0.012% (max), and everything else
< 0.004%. No iron and definitely no zinc.
I didn't find a composition for refined nickel ca. 1857, but note that 1857 was a few years before electrolytic refining and many years before the Mond (carbonyl purification) process. Iron & cobalt are usually the greatest impurities in smelter nickel prior to electrolytic refining. Circa 1936, commercial purity nickel was about 99.2% Ni (+Co), 0.4% Fe, 0.2% Cu, 0.1% Mn, 0.1% Si, 0.1% C, 0.005% S. Composition from
Metals Handbook, 1936 Edition, p. 1257.
Of possible interest:
"Nickel silver is a metal alloy of copper with nickel and often but not always zinc. It is named for its silvery appearance, and contains no elemental silver."
Various 19th century uses & trade names of nickel silver:
