benwr
- Oct 30, 2009
- 10
I am building in Northwestern Ontario (Canadian Shield) on bedrock. I had the site scrapped down to rock when i had my road built and will shoot some elevations this weekend.
The area is fairly flat with only a few impressions, i would estimate the elevation difference, highest point to lowest point be approx 2ft. I will know for sure by Monday.
I am building a one level home, with in slab heating. I was planning on a thickened edge slab as shown in the attachment. I am not interested in a crawlspace, as I see the problems they create everyday ay work (I know if they are built correctly they can be problem free, but want to avoid it).
I had a builder I know looking at my site and he was concerned that bringing in fill for a thickened edge slab is a bad idea, as the hydrostatic pressure would cause it to move down hill (it slopes slightly towards the water and a very high cliff for that matter)and will not get a good compaction.
I am sure many of you are firm believers of building on bedrock, as all contractors/engineers in this area are.
I am looking for inputs on how to scribe my footings to bedrock, while having a "slab on grade" type home. I will attach another sketch, showing a 10inch footing, scribed to bedrock, 8 inch min height, with a 6 inch slab on top I am thinking of. My concern with this is the rebar left exposed that will go into the slab will be in the way of the compactor. A guy i work with assumed they can just bend the bar down after compacting the fill and laying the ridged insulation, but his background is in mining.
I am fairly new to foundation design and all the input is appreciated.
