harlowmatt
Aerospace
- Nov 11, 2014
- 71
Hi all,
I have the following macro to convert a BOM table in a catdrawing to a Excel spread sheet but it gets hung up at line 6 "Dim drwdoc As Document". i would greatly appreciate any help. my knowledge of macros is VERY basic and limited.
Sub TableToExcel()
'\\Global Declarations
Dim bigstring
Dim totalrows
Dim totalcolumns
Dim drwsheets As DrawingSheets
Dim drwsheet As DrawingSheet
Dim drwviews As DrawingViews
Dim drwview As DrawingView
Dim drwtables As DrawingTables
Dim drwtable As DrawingTable
Dim objExcel As Object
Dim objWorkbook
Dim object
Dim object
Dim InputObjectType(0)
Dim i, j, k, r, c
Dim IsExcelRunning As Boolean
Set drwdoc = CATIA.ActiveDocument
If TypeName(drwdoc) <> "DrawingDocument" Then
MsgBox "This macro can only be run with a drawing document.", vbInformation, "Document not a Drawing"
Exit Sub
End If
Set draw sheets = drwdoc.Sheets
'Here I capture whether MS Excel is running already or not so we don't close it on the user
On Error Resume Next
Set objExcel = GetObject(, "Excel.Application")
If objExcel Is Nothing Then
IsExcelRunning = False 'false if user does not have excel running
Err.Clear
Else
IsExcelRunning = True 'true if the user has excel running
End If
On Error GoTo 0
'run thru every sheet
For i = 1 To drwsheets.Count
Set drwsheet = drwsheets.Item(i)
Set drwviews = drwsheet.Views
'run thru every drawing view
For j = 1 To drwviews.Count
Set drwview = drwviews.Item(j)
Set drwtables = drwview.Tables
'run thru Tables
If drwtables.Count > 0 Then
For k = 1 To drwtables.Count
Set drwtable = drwtables.Item(k)
'--Define table and extract strings to array.
totalrows = drwtable.NumberOfRows
totalcolumns = drwtable.NumberOfColumns
Dim table()
ReDim table(totalrows, totalcolumns)
For r = 1 To totalrows
For c = 1 To totalcolumns
table(r, c) = drwtable.GetCellString(r, c)
Next
Next
'--Open Excel
Set objExcel = CreateObject("Excel.Application")
Err.Clear
objExcel.Visible = False
End If
On Error GoTo 0
Dim myname
myname = Left(drwdoc.FullName, Len(drwdoc.FullName) - 11) & "_" & & "_" & & "_" & & ".xls"
Set objWorkbook = objExcel.Workbooks.Add()
objWorkbook.Activate
Set objSheet = objWorkbook.Worksheets.Item(1)
'--Populate spreadsheet with values from array.
objSheet.Cells(r, c) = table(r, c)
Next
Next
objWorkbook.SaveAs myname 'ExcelWorksheet.SaveAs sFile
objWorkbook.Close
Next k ' table loop
End If
Next j ' view loop
Next i ' Sheet loop
If IsExcelRunning = False Then
MsgBox "There are no Drawing tables to exprot.", vbInformation, "No Tables to export"
Exit Sub
End If
objExcel.Quit ' Close Excel with the Quit method on the Application object
MsgBox "Your Catia drawing tables have been exported to Excel.", vbInformation, "Table Export Complete"
End If
End Sub
Sub TableToExcel()
Dim bigstring
Dim totalrows
Dim totalcolumns
Dim objWorkbook
Dim object
Dim object
Dim i, j, k, r, c
Exit Sub
End If
Err.Clear
Else
End If
On Error GoTo 0
'run thru Tables
Dim table()
Next
Next
'--Open Excel
Err.Clear
End If
On Error GoTo 0
Dim myname
Next
Next
objWorkbook.Close
Next k ' table loop
End If
Next j ' view loop
Next i ' Sheet loop
Exit Sub
End If
End If
End Sub
