Engineer2345
- Oct 2, 2012
- 6
It was recently brought up at the place I work that the mezzanine could possibly be overloaded. I calculated the point load on some 50 gallon barrels (the heaviest thing we have up there). Each barrel is 22.5" in diameter and weighs 200 kg. I calculated a load of ~160 lbs/ft^2. The mezzanine is specified to a max live load of 100 lbs/ft^2. My initial thought is that these barrels should not be up here, but the other engineer in the office told the boss that it is ok, nothing to worry about. Supposedly they specified these barrels when they built the mezzanine (before I came here), but didn't know the exact weights of them. I figured the engineer used water as a guess, but this still gives me ~151 lbs/ft^2. We store 12 of them on 2 rows of 6 almost against each other. There is very little chance of them all being full at one time. Should I be worried about this or could this be acceptable?
Thanks.
Thanks.
