Need Help 1
djpeterlewis
Hi all
I am looking for someone who can draw a circular sheet of aluminimum 5mm thick and place 4 slots on a specific part of the plate and then using the pattern feature or mirror feature copy these 4 slots 50x in a circular direction
If you can help I would appreciate it , i am new to Solid Edge v19
Peter
Sorry, Just to give you an idea what I am looking to do
The circular plate is 560m diameter and there must be 52 of the Holders around this plate.
Please find my version of the holder and the plate and my attempt to assemble on the site in a rar file
I have already tried to assemble them but my knowledge is limited
Thanks for your help in advance
attached find the completed assembly. I've changed
the angle of the holder's flange otherwise they would interfere
with each other on assembly. There is still some room for
improvement. I've not included your original parts.
The cutout on the angled flange is done by modification
of the flange's profile after it has been created. The lower
tabs are created by cutout.
HTH
dy
 http://files.engineering.com/getfile.aspx?folder=4283b99f-8b8f-4a9d-a281-ca75f2728208&file=Holder_V19.zip
