I'm a bit confused on what is meant by an "800#" valve, and other vague specifications. I'm guessing this info is meaningless unless there is additional information, such as WOG or WSP.
I'm familiar with ANSI 16.34 and its associated classes, but I don't think these class numbers are used in typical manufacturer lingo.
Can someone fill me in on what the language is for valve suppliers, especially for small bore valves, such as 3" and under ball valves. Flanged 4" and up are pretty standard, all references are clearly for 16.34.
Also, if I'm designing a system for B31.3, its not enough to say "1000 WOG", if there is no other mention of an associated code, right?
Thanks for the input.
