need same assembly saved twice, with same components but different part numbers
tcmain47
Automotive
I need an assembly saved twice, they will have identical components but different part numbers.
As one will be saved for the customer with their P/N's and the other for internal use.
If I use the save as, it will rename that component in both assemblies.
Do I really need to copy the prt file then rename it and swap it out in the other assy?
Is there a simpler way?
Thanks in advance!
Question, are the part numbers attributes? If so, couldn't you just reference different attributes, I'm assuming, in a drawing or bom?
NX 1899 Windows 10
Have you looked in CLONING ?
Jerry J.
UGV5-NX1884
Hi
I will without doubt, recommend you, to dive into the Clone utility in NX ...
If not you are familiar with this tool, use some time on it....
It is worth...
Lklo
