itsmoked
- Feb 18, 2005
- 19,114
I have to connect sixteen 2AWG cables probably with lugs with 5/16" or 3/8" holes unless someone has a lugless solution.
These batteries have odd terminals that are 0.560" in diameter and about 2" long.
I need a 200Amp connection between the cable and the battery terminal.
Some sort of split tube?
Some sort of split bars with a a trench in their faces?
Slit block with a hole thru the center?
Keith Cress
kcress -
Keith Cress
kcress -
