We updated to NX1969 recently and now it will not record a USER ENTRY function in a macro. It always errors out in playback right at the User Prompt line.
I was wondering if someone who has the same version (NX1969) can do me a little favor and record a macro to change the color of a solid body and use the USER ENTRY before selecting the body.
Please play it back once to make sure it runs through for you and does not error out. Then I will try to run it and if it errors out on me, I will know the problem is in our playback. If it works right, then I can compare the USER ENTRY line that ours always errs out at and see what it is doing wrong in recording.
Ken
My brain is like a sponge. A sopping wet sponge. When I use it, I seem to lose more than I soak in.
Ken
