Need to calculate least size bounding box REGARDLESS of coordinate system 6
John-FR
Computer
Dec 16, 2020
13
I have a need to find the very smallest box some solid bodies can be contained within. the bounding box cant work because the parts are too complicated/not square to the absolute coordinate systems or any other coordinate system. Is there a command or grip program that will perform this? Can it be done in another CAD software?
In the measure command, you can change the bounding box method to "best fit", which will attempt to minimize the volume of the bounding box. Does this help?
www.nxjournaling.com
I don't see that command sequence can you show me?
The "best fit" alignment tool in the reverse engineering looks interesting, but it is not what I was referring to.
In the measure tool, there is an option for a best fit alignment bounding box. Start the measure tool, make sure the "other" measurement result is turned on, in the measure -> settings -> preferences -> general -> change the bounding box method to "best fit". In measure -> settings -> preferences -> measurements -> other, make sure the "bounding box" option is turned on. Set the selection to object and pick a solid body, a bounding box with measurements will be shown around the body.
YES! this works~! You're brilliant Cowski
I never knew about Best fit in Measure.
I always use this method
Wow, didn't notice this option. Already added this to a component that gets modified and re-used constantly and it will both save time and insure accuracy. Always assigned sizes to attributes with a journal and would have to update it with every change. Opening the way-back machine, using an idea from a post by John Baker, I wrote a journal to get the size of an object using planes before this type of measurement option was ever available.
NX 2212 Windows 10
