won13
- Jun 12, 2003
- 3
After surge analysis of forcemain (510gpm with C-900 CL 150 8-in pvc pipe), we found there will -16.5 ft negative pressure in case pump shuts down. Our analysis showed one 750 gallon surge tank can reduce to -2ft. But we don't want to install any surge tank.
What is commonly accepted negative pressure for PVC?
Is there any spec specifies allowable negative pressure for PVC?
Thank you.
Thank you.
