gg8014
Aerospace
- May 21, 2015
- 1
Recently our company has transitioned from using NEi Nastran to NX Nastran as our FE solver. In doing so we notice some significant differences in the results for the same models. Our models are fairly straightforward using linear static SOL101. One of the first differences that we noticed was the displacements for the RBE3 elements used to connect point masses to our structures. The displacements using NEi were small in comparison to the NX results especially as the mass values increased. We posed this question to our support representative. His response was to remove the rotational degrees of freedom from the RBE3s independent nodes. We did this and the large deflections decreased such that they were comparable (although not exactly the same) as those when the model was run in NEi. On comparing the results of the constraint forces and moments between the two solutions we saw that there were differences in some cases approaching 10%. Again we are using the exact same model in both solutions. While this might not be an issue for some situations it is an issue when models that were accepted by our clients are re-run using the NX platform (at their insistence) and they see that the results have changed. The question is which platform is producing the more correct results?
