bldgdesign
Existing one way slab and beam floor system. New equipment leg is to be located near center of slab instead of on an existing beam and the slab can not handle the point load. Has anyone ever installed a new concrete beam between existing concrete beams in order to support the equipment leg or column from above.
Other options are to install a steel column up to the underside of the slab and locate under each equipment leg; slab would have to be checked as continuous beam.
cut opening in slab and install steel column through slab to support equipment above. This would be a frame with bracing below slab.
install steel or concrete transfer beam on top of slab to span between exisitng concrete beams. Would make beam stiffer than slab to avoid overloading slab.
Without providing all the details (equipment is a combustion turbine with a 32 kip load at each of it's six supports), any suggetions. Don't discuss dynamic loads, only trying to get as many viable options as possible for supporting the static loads.
Thanks for your help.
