new perspective at Solid Works 2
SanRox
Industrial
Nov 1, 2005
12
I would like to know if I can add a extra perspective at Solid Works. You've got already Isometric,Trimetric en Dimetric, but I would like to add the next perspective: from left to right 30 degre,90 gdegre,60 degre
How can I add this perspective?
Sanrox,
I updated the macro for my own use to work in SWx2005
Sub main()
Set swApp = CreateObject("SldWorks.Application")
Set Part = swApp.ActiveDoc
pi = 4 * Atn(1)
Z = Tan(30 * pi / 180)
X = Atn(Z / Sqr(-Z * Z + 1))
Y = -45 * pi / 180
Part.DeleteNamedView "TRF-ISO"
Part.DeleteNamedView "TRR-ISO"
Part.DeleteNamedView "TLF-ISO"
Part.DeleteNamedView "TLR-ISO"
Part.DeleteNamedView "BRF-ISO"
Part.DeleteNamedView "BRR-ISO"
Part.DeleteNamedView "BLF-ISO"
Part.DeleteNamedView "BLR-ISO"
Part.ShowNamedView2 "*Front", -1
Part.ActiveView().RotateAboutCenter X, Y
Part.ViewZoomtofit
Part.NameView "TRF-ISO"
Part.ShowNamedView2 "*Right", -1
Part.ViewZoomtofit
Part.NameView "TRR-ISO"
Part.ShowNamedView2 "*Back", -1
Part.ViewZoomtofit
Part.NameView "TLR-ISO"
Part.ShowNamedView2 "*Left", -1
Part.ViewZoomtofit
Part.NameView "TLF-ISO"
Part.ActiveView().RotateAboutCenter -X, Y
Part.ViewZoomtofit
Part.NameView "BRF-ISO"
Part.ViewZoomtofit
Part.NameView "BRR-ISO"
Part.ViewZoomtofit
Part.NameView "BLR-ISO"
Part.ViewZoomtofit
Part.NameView "BLF-ISO"
Set Part = Nothing
Set swApp = Nothing
Set swApp = Application.SldWorks
End Sub
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
Dang it, I forgot about CBL's FAQ on uploading files. here is the link to the file.
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
o
_`\(,_
(_)/ (_)
Heckler ... The author of the original FAQ (StarrRider) does not appear to be active in the forums (since 2004-01-06 anyway), so perhaps you should post a new FAQ for the updated macro.
[cheers]
Helpful SW websites faq559-520
How to get answers to your SW questions faq559-1091
Scott, MadMango, Theo ... A small point, but using the arrow rotation method will not give true Isometric perspective views. Compound angles come into play.
Select the SW Isometric view of a part & then try to get back to a regular planar view, using the arrows, to see what I mean.
[cheers]
I also store predefined views in my drawing template. One is called "TitleBlock" and is very easy to get to from the tool bar or a macro.
Hardie "Crashj" Johnson
