New to Teamcenter question
jerry1423
3,428
I am new on Teamcenter and have yet to have any in-depth formal training, but I am OK with finding my way around it.
I have a part that needed to be changed so I copied it to a new revision.
Now under that part number there are two versions rev 0 and rev 1
The guy changed his mind and no longer wants the part revised.
So how I can I delete that part number with rev 1 from Teamcenter ?
yes if it is not used in any other assemblies and or in other user's folders. If you made a change then opened an assembly and the part rev 1 is now in that saved assembly you can not delete it. The best way of doing this is open the rev 0 part and save it to a rev 2 if this is possible with your standards.
You should be able to just delete it from Teamcenter if it has been used in imprecise assembly.
If for any reason it has been used in another precise assembly then go to that assembly and replace it with the former revision of the part. After that you can delete it.
If no where else used then just delete...
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
Actually, even if it is not used in an assembly you may not be able to delete it if it is referenced somewhere or by something. Just replacing the part in the latest assembly may not work either if it was used in a prior revision. You will need to remove it from all assemblies and delete any references that it may have.
