TroyD
- Jan 28, 2011
- 98
Client has an existing warehouse (1970's) and looking to upgrade the exterior. See attached sketch. 12" CMU block walls, metal roof deck supported by steel bar joists. Client wishes to add pre-finished vertical steel to the exterior walls, and new mono-slope roof trusses, with 2x purlins and steel roof. I'm not sure the best way to secure the new trusses to the existing CMU wall. The existing roof joists and deck will remain. The roof material is likely rubber membrane, with rigid insulation underneath. I figure the rubber and insulation should be removed because the new trusses will crush it. The Simpson catalog has several pages of products for attaching trusses to CMU walls, but will need to penetrate thru the metal deck to do so. Does it make sense to cut out small areas of the metal deck at each truss location as needed to access the CMU wall below? I assume the top course block is a bond beam grouted solid. Any advice or suggestions is appreciated.
