Newbie: how to make a radial restraint
Jolilechat
5
Hello!
I am starting to learn ANSYS and I'd like to ask for some help. Consider a plate with a hole (see code below).
Please, can you explain me how to create a radial restraint for the hole (that is, the plate can only rotate about the axis of the hole)?
Thank you very much!
/prep7
/title,Plate
l1 = 80.0E-3
l2 = 250.0E-3
l3 = 50.0E-3
a = 20.0E-3
b = 15.0E-3
th = 20.0E-3
ET,1,SHELL63
R,1,th,th,th,th
MP,EX,1,2.0E11
MP,PRXY,1,0.3
TYPE,1
REAL,1
MAT,1
BLC4,0,0,l1,l2
CYL4,l1/2,l3/2,5.0E-3
ASBA,1,2
FINISH
Hi
You can determine your boundary conditions by applying your displacements on the lines of the hole.
Grtz Garry
You say zero to displacements at all nodes of the boundary of the hole?
If I do it, the plate won't be able to rotate.
set up a locale cylindarical coordinate at the hole senter. Then applied constraint along the radial direction.
EricZhao,
what you said is not complete. Independent of the active coordinate system, the nodal displacements are in the nodal coordinate system. So:
1) set up a locale cylindarical coordinate at the hole center:
Code:
local,1000,1,xcenter,ycenter,zcenter
2) select nodes on the circle:
Code:
nsel,s,loc,x,rad
3) Rotate nodal coordinate sistems in the cylindrical coordinate system:
Code:
nrotat,all
4) constrain nodes along the radial direction:
Code:
d,all,ux,0
Jolilechat,
in your concrete case:
Code:
smrtsize,4
amesh,all
local,1000,1,l1/2,l3/2
nsel,s,loc,x,5e-3
nrotat,all
d,all,ux,0
/PBC,U,,1
nplot
