andrewward
HI All,
what is the difference between "Newton Raphson Classical" and "Newton Raphson Current Loop"?
The NR Current Loop method seems to solve much more easily, especially for my power sytem that has voltage problems in a particular area. Actually the NR Classical won't converge, but the NR current loop does.
Is NR current loop as accurate NR classical, or does it use approximations that result in a less accurate solution?
