SprinklerDesigner2
- Nov 30, 2006
- 1,264
I got a job where I have to use trapeze hangers with an 11'-6" span. Looks like I will be going with Unistrut.
I know the P1000T strut won't work for the long spans but looking at it as an example it has two Section Modulus; one for Axis 1-1 (.202) and the other for Axis 2-2 (.290). Question is which Axis would be appropriate to apply with NFPA #13 Table 9.2.2.6.1(b)?
Indeed, is either one appropriate for use?
Then there is the "Beam Loading - P1000" chart. I guess I am not clear on understanding exactly of what a "Uniform Load" means. With a trapeze hanger the load isn't spread "uniformly" so I would be leary of hanging 480 lbs from a 84" span.
And while I am showing how much I don't know what does the "Uniform Loading Span/180" etc mean?
This is the first time I've ever had to deal with a trapeze hanger > 10'-0".
