This is an application of using Nitrile blocks as foundation shock absorbers; the type of application one would see in a seismically active area.
My question concerns Nitrile and how its shock absorbing (static and dynamic spring constants) change with time.
Questions:
I understand there are different spring constant for static and dynamic loading, but I haven't been able to find out if these spring constants (k-values) remain the same over a period of many years (say 50 years). After being compressed for many years, how do the k-values change?
Should I expect these isolators to respond differently (increased stiffness)?
Is there a similar change in k-value if the isolators are not statically loaded?
Any literature, data, or manufacturer's references would be very helpful.
Thank You,
mm
Questions:
Thank You,
mm
