Techciv
- Apr 8, 2012
- 4
I'm hoping to get SAP to highlight the failing NLLink elements in my structure). I understand that the design function is able to check for and highlight the failing steel and concrete elements.
I made a simple frame, with Linear Link element on diagonal, I also made the same frame with Damper, MultiLinear Plastic and MultiLinear elastic Link element. I assigned the force at top left joint. I think, when I assign a big force, the Link element should break, but program doesn't give me the note that Link element is failed.
I'm just hoping to find out if there is a way of checking for failing Link elements.
I have done it in SAP 2000 version 14.0
Thanks in advance!
Thanks in advance!
