No output database (ODB)
Manask
3
Hi All,
After creating and completing analysis of my job, I save it in the default directory. But when I try to reopen the previous model later and go directly to the result tree, it cannot show me the results as earlier and gives a message like - "There is no output database associated with the current viewport". And if I go to file->open, no ODB file is there to open in the default directory.
Plz help!
Reagrds,
Manas
You need to open your results using abaqus viewer.
Open directly the odb file or open abaqus viewer (write that in a dos commmand window)and then open your odb
