No Results File was selected and the Results File bending.frame1.xdb for job bending.frame1 does not
ataseventurgut
New member
Nov 4, 2021
6
Hi, I am new to Patran.
When I tried to access to the results of my bending frame job (XDB), I got this error.
No Results File was selected and the Results File bending.frame1.xdb for job bending.frame1 does not exist. Please select an existing Results File.
I have uploaded the necessary files.
What is the problem? Does the error occur because I run it in an F: file, or is this irrelevant?
Also, is it possible to have a tools tab like that or is it a removed/old feature?
I have solved this problem by changing output format from Preferences., but the command window at the bottom is missed. How can I display it?
Nevermind I found it out too, just right click on top of PATRAN and click Command Window.
