*NODE PRINT v6.4 and 6.2
smg2
4
I am hitting a wall to figure out this problem, and would appreciate any help from anybody. I am using a fluid element:
*NODE,NSET=NGAS
3000,0.0,-0.0025,0.0
*FLUID PROPERTY,REF NODE=NGAS,ELSET=GAS,TYPE=HYDRAULIC
Then I want to output the volume and pressure of this gas:
*NODE PRINT,FREQUENCY=1,NSET=NGAS
CVOL,PCAV
I can do this fine in v6.2. But I am now running the same code with v6.4 and this is what I get:
THE FOLLOWING TABLE IS PRINTED FOR NODES BELONGING TO NODE SET NGAS
NODE FOOT- CVOL PCAV
NOTE
ALL VALUES IN THIS TABLE ARE ZERO
As far as I have gathered from the documentation, no changes have been made to the commands related *FLUID. Further the history output in ABAQUS viewer works fine, giving finite values of the two variables. Could anyone please help me? unfortunately I am using an academic license and hence cannot direct my enquiries to HKS. Thanks a lot!
smg2,
On the ABAQUS website, there is a known bug listed on the status reports as error number V64_1808, which describes your problem pretty much to the letter. (A copy of the report message is shown below)
The output variables hydrostatic fluid gauge pressure
(PCAV) and hydrostatic fluid cavity volume
(CVOL) are incorrectly reported by
ABAQUS/Standard as zero in the data (.dat)
file. The correct, non-zero values appear in
the results database (.odb) and can be probed
or visualized.
IDENTIFIERS: FLUID_PROPERTY,NODE_PRINT output
This has been corrected in 6.4-3
As it says, its been corrected in V6.4-3. You should have access to this maintenance release as part of the academic license. Hope this helps.
GJS
Unfortunately, I am running v6-4-1, not 6.4-3, so I have had to change my script file to read from the odb file instead, which turns out to be neater (and the code is much simpler) than what I have been doing all this while with the .dat file.
