robindbois
- Oct 1, 2002
- 25
A couple of month ago I started a topic concerning a set of a small pinion and an internal gear assembles in parallel axis. I had to explore many setting in order to reduce noise. There is almost no load to transfert.
Choice was to use plastic internal gear so I made one in 6061 and another one in plastic. The other choice was to explore the helical type of gear set. I designed and ordered straight and helical gears in both plastic, stainless and 6061 to explore all possibilities.
I have in my hand all gears excepts the internal helical gears. I installed the straight set made of a stainless pinion (12 teeth 48 dp offset of 50%) and the internal gear (244 teeth, no offset) made of 6061 (I have one in plastic too).
The strange thing is that the noise is different if I move by hand the gears in one or the other direction. What can be the cause? Is it possible that the cutter do not do the same quality in both face of each teeth?
Robin
Robin
