op9
Industrial
- Aug 18, 1999
- 111
I have a gear pump installed pumping diesel oil. Specifically it is a Viking HJ4195 running at 1450rpm (4pole 50Hz supply) at 66psi delivery pressure. The suction is supplied wth a head of about 6ft plus and we have checked the pressure at the inlet port during operation and it is 5psi or higher depending on liquid level in the fuel tank.
The pump is a new installation and has been noisy (sounds like a bag of old bolts...grinding raspy sound)from the start. I have had the supplier look at it and they are at a loss. A new pump was supplied last week and after installation and alignment it was just the same.
Just a few more notes:
1) Pump alignment is OK
2) Current draw is fine and pump is free and its own bearigs OK.
3) Motor is new, bearings fine and runs separately smoothly.
4) Going on inlet pressure measurement does not appear to be a cavitation or NPSH problem
5) Internal relief valve is not operating as pressure is set by external pressure regulator (returning to tank) and internal relief opens at about 85psi (delivery press 66psi).
6) The only thing I am considering is that the pump is installed with two 1-1/2" flexible connections (convoluted SS covered with braid about 12" long) see attached photo, to alleviate any piping stress on the pump. Could these be causing irregularities in the flow as the bore is not smooth as would be the case with rubber hose?
Has anyone had similar instances when using convoluted SS flex to supply pumps?
Any comments would be appreciated.
Thanks in advance,
Rod
Rod Nissen.
Combustion & Engineering Diagnostics
Thanks in advance,
Rod
Rod Nissen.
