I'm designing a part and I had a question about additional cost but I'm not sure if this really affects my part.
One tolerance on the part is originally called out as .095+- .002
I asked my suppliers if the true nominal value could be called out without additional cost, .0948+-.002.
They responded and said there's no cost associated as it doesn't buy any additional tolerance and they can measure to 4 decimals, however, doesn't this add .0002 of tolerance adjustment? Wouldn't the .0948+-.002 limit the part to .0968 and .0928 rather than .097 and .093 or would the .002 be rounded from .00249 and .00195 so the min and max are actually +-.00249?
Simply put, does a .xxx callout mean suppliers can round from +-.xxx49 back to .xxx?
