AppleJaxJap
can not find guidance in 70E or IEEE.
This issue makes VERY little difference in the calculation BUT I still want the reference
UPS
40 bats @ 12V = 480Vdc But
Float voltage is 2.25V Per Cell so the actual voltage on the bus when maintenance is being done is 2.25 x 6 x 40 = 540Vdc
I use the 540Vdc in the AF calculation as it provides a more conservative result (CYA)
Where this really makes a difference is in 96Vdc inverters.
<100Vdc does not need a calculation done but if you use the float voltage you are at 108Vdc and it does.
looking for some reference IEEE or other white papers that might provide guidance on this calculation voltage should be used.
This is your life and its ending one moment at a time.
UPS
