Non-circular reinforcing pad EN 13445 / ASME VIII-1
FPPE
196
I would like to ask you, with reference to the image below, whether the reinforcing pad in option 2 (non-circular), which features an unwelded portion, is acceptable under EN 13445 and ASME VIII-1.
In my opinion, the "extra" area outside the circular projection of the reinforcing pad might indeed contribute structurally, but it could also cause stress concentrations on the circular part which, if fully welded as in option 1, would likely be avoided.
Are there any specific requirements or provisions in the codes (EN 13445 or ASME VIII-1) regarding this?
ASME Section VIII clause UG-42 addresses closely spaced openings.
We always join the two circles with tangential lines rather than the "bar bell" shape you've shown.
Poor design. How about: One pad, two holes, fully welded...
Mike
I don't like this design.
It's difficult to perform an air leak test.
If a leak occurs during service, you can't tell which nozzle it's coming from.
Hi, thank you all for the feedback.
Are you also familiar with the EN 13445 requirements on this matter?
