Noway2
- Apr 15, 2005
- 789
I have two questions regarding (non fusible) disconnects that I would like to ask:
1 - I have been told by a manufacturer that it is an NEC violation to add a fuse to a "non fusible" disconnect. Is this true?
2 - With a fused disconnect, for service entrance, do the fuses go up or down stream of the disconnect switch? From what I am reading, it looks like they go upstream of the disconnect, but then to replace a fuse you would either need to suit up and work live or disconnect the service at the transformer.
